Body lift Questions
Old Aug 20, 2003 | 08:08 PM
greg7097's Avatar
greg7097
Default Body lift Questions
I am lifting the body of my 1970 this weekend and i have two questiions i hope someone can help me with
1) i bought a set of body lift straps. Where on the body do i locate them to lift the complete body nose and all?
2) the body mount bolts by the gas tank both broke off. does anyone know how i can get the studs out? OR DO I HAVE TO DRILL THEM OUT?
P.S. 427basketcase I got the straps THANKS! i will send you the rest of the money tommrow
Old Aug 20, 2003 | 08:51 PM
427basketcase's Avatar
427basketcase
Default Re: Body lift Questions (greg7097)
Hey, glad you got the straps in time. The best lift points are just in front and just behind the doors. Some of the catalogs that sell the lift lit have an illustration that shows that. Some people rig up a little extra strap for the nose because there is a little more weight out there. (a problem I did not have) Just go slow and easy and make sure everything is disconnected.
You will most likely have to drill out the broken studs but they will be real easy to get to once the body is off.
Good luck! :thumbs:
Old Aug 20, 2003 | 09:46 PM
Simul8's Avatar
Simul8
Check my site(In sig), I have some pictures of when I did my lift.
Old Aug 20, 2003 | 09:51 PM
Chris@VetteFinders's Avatar
Chris@VetteFinders
Platinum Supporting Dealership
Default Re: Body lift Questions (Simul8)
MAKE SURE you support the nose. It is likely to cause the fiberglass to pull away at the windshield and possibly other places as well if you don't.
Old Aug 20, 2003 | 10:35 PM
greg7097's Avatar
greg7097
Default Re: Body lift Questions (Chris@VetteFinders)
Thanks guys!! that link really helped
wish me luck i will be lifting it on saterday!
SO the broken bolts should come right out? I was worryed bcouse it looks like they go into the body there is no way to get to them from the other side and i would be screwed
Old Aug 20, 2003 | 10:44 PM
redwingvette's Avatar
redwingvette
I put a list of things to look for when removing the body. The rear bolts that broke off have a nut on the top inside the car. It would be easier to cut it off than to try and drill the bolt out. Look to http://www.corvettefaq.com/ for more info on what to do. I used a come-a-long on the nose as well as the lifting straps to lift mine off.
Old Aug 20, 2003 | 10:55 PM
noskillz's Avatar
noskillz
I did the same thing as you #2 - broke the bolt off. However, with the body off I was easily able to put a Stilsen wrench on the broken bolt and turn itout.
Old Aug 20, 2003 | 11:49 PM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
Redwingvette just went through this and his link (posted above) should clear any questions you might have. The only suggestion I wish to make is be careful if your rocker channels are all rusted out, there may not be enough structure there to support the weight of the body. I lifted mine using slings that I worked completely under the body and it worked well. :cheers:
Old Aug 23, 2003 | 06:33 PM
greg7097's Avatar
greg7097
Default Re: Body lift Questions (Big Fish)
Well it came off no problem thanks guys
Old Aug 24, 2003 | 12:35 AM
427basketcase
:thumbs:
To Body lift Questions
