1981 Vette with LT-1 motor
Old Aug 23, 2003 | 04:03 PM
kaz1961's Avatar
kaz1961
Default 1981 Vette with LT-1 motor
Found a listing for a 1981 with a 350 LT-1 motor. Is this good, bad or neutal? Before I call and look stupid I would rather look stupid here. Any specific questions you would ask about this motor? Any info on the LT-1 would be appreciated.
Old Aug 23, 2003 | 04:15 PM
Robert N's Avatar
Robert N
Default Re: 1981 Vette with LT-1 motor (kaz1961)
What year LT-1?
Old Aug 23, 2003 | 04:18 PM
kaz1961's Avatar
kaz1961
The ad doesn't say. What years were they made?
Old Aug 23, 2003 | 04:37 PM
Robert N's Avatar
Robert N
70, 71, 72 for the early ones, C4s (not sure of the years) are the late model fuel injected versions. If it is an early one, the year the engine is spec built to will help determine value.
Old Aug 23, 2003 | 07:08 PM
page62's Avatar
page62
The oringal LT1 was a solid lifter, high-compression engine. No way the car would pass emissions (if you have them in your area).
Or it could be the 90's vintage fuel-injected LT1 as found in the C4, Z28, and Impala SS.
Old Aug 23, 2003 | 10:56 PM
LAvetteman's Avatar
LAvetteman
St. Jude Contributor
Default Re: 1981 Vette with LT-1 motor (Robert N)
The FI LT1 found in the C-4's ran from 92-96. As mentioned above the 1st generation LT-1 setup will have solid lifters (more maintainance), and problems passing emissions in some areas. If someone went through the trouble of setting up the car for the 2nd generation LT1, like whats in the 92-96's than you have a strong, reliable, efficient engine.
As with any corvette purchase check the numbers on the engine. Very possible it is neither LT1. Some people will call a vette engine whatever happens to fly out the as..... I mean mouth just cause it sounds good.
To 1981 Vette with LT-1 motor
