frame repair sections
Old Aug 25, 2003 | 11:23 AM
houstoncajun's Avatar
houstoncajun
Cruising
Default frame repair sections
Does anyone know where i can get some frame repair panels for a 80 vette? can you repair this without pulling the body off? the car runs and drives ok now but i'm scared of the frame.... any help would be appreciated
Old Aug 25, 2003 | 11:35 AM
sray454's Avatar
sray454
Default Re: frame repair sections (houstoncajun)
Yep - Corvette Central, Beirs and others carry them. I've read where the repairs can be done without removing the body, but it is not easy ( ie. cheap ) either way...
Old Aug 25, 2003 | 12:21 PM
DVG73's Avatar
DVG73
Paragon sells them as well. I think it would be difficult to repair it with the body on. You gotta weld them in and it would much easier to do it with the body off but either way you go it is going to be a PITA. Good luck.
Old Aug 25, 2003 | 02:21 PM
houstoncajun
Cruising
Thanks guys,
I;m thinking I can lap weld the lower section in to form the box channel. right now it looks like a c looking at the ground. It has good metal holding it together so I'm thinking get the rust off then por 15 it then weld the channels back in while keeping the frame level. Do you think this is an ok way to do it? this is my first time trying to do this, am in over my head? :confused:
Old Aug 25, 2003 | 05:47 PM
houstoncajun
Cruising
here is better pics :confused:
Old Aug 25, 2003 | 06:17 PM
Red69's Avatar
Red69
Chris,
I dont mean to rain on your corvette parade, but the pictures of your frame look pretty bad. It becomes a saftey issue when a frame rotts from the inside out.... which I beleave the pictures you posted indicate. Many places wont work on a car that is rotted that bad because of the liability issues.
There are bound to be other areas that are equally rotted but can't be seen. There are probally several options... I understand cost is always an issue. Repairing may be good to a point for small sections - replacement may be better in the long run... and cheaper all arround. Not sure what your skills are... always best to get several opinions from shops in your area before making a decision.
Good luck!
Old Aug 25, 2003 | 06:23 PM
DVG73's Avatar
DVG73
Man that is ugly, but a typical location where they rust out. You might be able to make a U channel and weld it but don't know how substantial that will be. The frame is made from two pieces of basically U channel welded together. If it helps I have an old frame I can cut up and send you some of the frame rail. I was wondering how to get rid of it. I did use a small portion of the left rear prior to the kick up to fix my donor frame. If you buy replacements they will be the whole rail anyway. You might be able to cut mine in half and use that as your U channel. You can take your rocker panel off and that gives you some more room but on the inside portion it is going to be tight. I still think you are better off lifting the body as you can do a better job of repair. Let me know if you would like to try the frame rail I have it's yours for the shipping. Good luck
Old Aug 25, 2003 | 09:52 PM
dath's Avatar
dath
Thanks guys,
Just a quick pointer if you do end up welding it (or anything else), though you may already realize this... Do not put the por 15 or other coating on before welding. You want the metal clean and the heat will take paint off quite nicely anyhow...
In the case of your frame, I'd find a donor car, that looks downright scary to me.
Old Aug 25, 2003 | 10:51 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Re: frame repair sections (Red69)
Chris,
Good luck!
:iagree: You need professional help. Seek a dealer recommened frame shop and get two or more estimates. Who knows, for a future drive-train you may want to go with custom tubular?
Old Aug 25, 2003 | 11:11 PM
gary6696's Avatar
gary6696
St. Jude Contributor '03 & '04
Where did that car come from? I hope not Texas.
I just went through some major frame repairs on mine, but it's problems were collision damage, not rust. Nevertheless, the cost of repair pieces was about $1600 and $800 for a frame pro to weld it.
I think you can find a replacement frame for a lot less. I've seen good ones for $1200-1500.
If you do weld pieces on it, then spray it with weld-through primer first, not POR 15.
[Modified by gary6696, 4:12 AM 8/26/2003]
Old Aug 25, 2003 | 11:28 PM
LAvetteman's Avatar
LAvetteman
Chris,
Good luck!
:iagree: I have allready offered my 80 frame that is for sale. IMO would be perfect for this kind of rehabilitation. The price is very reasonable IMO. And we are not that far apart.
To frame repair sections
