77 flooding problems
Old Aug 26, 2003 | 11:30 PM
tedo77's Avatar
tedo77
Cruising
Default 77 flooding problems
My 77 will run all day with no problems. However after I shut it down and try to restart it after it has been sitting for 2 or more hours the engine cranks and cranks. I smell gas so i wait about an hour with the air cleaner off and it finally starts. It's not vapor lock because the fuel squirts in when I work the throttle. If I start the the car after 1/2 hour or so it starts right up It's when the car sits that it is flooding although I see no gas poring in after it's off.
77 Coupe with Edelbrock Torker11 , Holley 650 Double pumper. The floats are adjusted properly. It runs like a bear otherwise from idle to high rpm and idles smooth. Any help would be appreciated. PS there is no choke on the carburator but there never was, in addition the "y" pipe and converter "fell" off when I put stainless duals on.
:) Thank You in advance
Old Aug 26, 2003 | 11:52 PM
FeedVaal's Avatar
FeedVaal
Default Re: 77 flooding problems (tedo77)
Hard to start with the engine cold, Hmmmmm.....
Old Aug 26, 2003 | 11:58 PM
tedo77's Avatar
tedo77
Cruising
Default Re: 77 flooding problems (FeedVaal)
Actually when the motor is stone cold it starts fine , It's when the motor is HOT that the flooding occurs. As I stated this is a flooding problem after the car sits for a couple hours not a choke problem.
To 77 flooding problems
