Another Start Problem Question?
Old Aug 27, 2003 | 07:51 AM
Vettesic's Avatar
Vettesic
Default Another Start Problem Question?
Occasionally when starting the vette I turn key and get nothing. Hot or cold. It's gotten so frequent that I installed a direct start button to the starter so I don't get stuck. All batt cables new, ground cable in front of motor cleaned and has a good ground. Starter fairly new. Batt fairly new. Heat shield on starter ok. What am I missing? Is this a possible column ignition problem? Any help would help. Thanks. Paul.
Old Aug 27, 2003 | 08:49 AM
vettemack's Avatar
vettemack
Default Re: Another Start Problem Question? (Vettesic)
Check your voltage at the "S" terminal of the soleniod. It takes a minimum of 7.7 volts to engerize it.
