81 Fuse Box
Old Aug 28, 2003 | 11:51 PM
PewterMetallic98's Avatar
PewterMetallic98
Default 81 Fuse Box
Where the heck is the fuse box and how exactly do I get to it??
Old Aug 29, 2003 | 02:12 AM
81' Corvette Guy's Avatar
81' Corvette Guy
Default Re: 81 Fuse Box (ElectronBlueC3)
The fuse box is way up behind the and to the left of the brake pedal on the fire wall. You have to open the door turn around and start like you doing a limbo...then lay on your back on the floorboard of the car with you head up under the dash and and look to your right and it is right there....in plain view silly. Good luck and before you try this ...get a tube of Ben Gay..as your back will be killing you after you get back up and out of the car...unless you pull the seats to get to the fuse box... :smash: :lolg:
Old Aug 29, 2003 | 02:34 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Default Re: 81 Fuse Box (81' Corvette Guy)
You could also hire the nearest 13 year old to do it for you. :D
Old Aug 29, 2003 | 01:07 PM
weendoggy's Avatar
weendoggy
Or, you can put it on a rack like I do. Saves my back. ;)
Old Aug 29, 2003 | 02:06 PM
PewterMetallic98
Default Re: 81 Fuse Box (weendoggy)
Ahh I found it, I'm BLIND!! Thanks guys ;)
To 81 Fuse Box
