Master cylinder/pwr booster question
Old Sep 1, 2003 | 09:20 PM
ettev's Avatar
ettev
Default Master cylinder/pwr booster question
Is there, or is there not supposed to be a gasket between the master cylinder and the power booster pod on early C3's (1970)? I know there is a gasket between the booster and the firewall, but am unsure if there's to be one in the other location.
Old Sep 1, 2003 | 10:36 PM
Jvette73's Avatar
Jvette73
Default Re: Master cylinder/pwr booster question (ettev)
I dont know if there is supposed to be one there or not but its definatly not required. Each of the two pieces are seperatly sealed. I think its better not to have a gasket there. That way if the master starts to leak the fluid will have a better chance of draining out, rather than pooling up and draining into the booster and ruining it.
Old Sep 1, 2003 | 10:47 PM
ettev's Avatar
ettev
Default Re: Master cylinder/pwr booster question (Jvette73)
Never thought of that, but you're right! None of the GM or aftermarket parts diagrams/listings call for a gasket between the two. Just at the firewall (whether it's a non-power m/c or the booster).
Thanks.
To Master cylinder/pwr booster question
