So much for 3.7 gears
Old Sep 4, 2003 | 07:21 PM
Glensgages's Avatar
Glensgages
Default Re: So much for 3.7 gears (TTop Tony)
Actually Glensgages that does make perfect sense thanks.
NOW that you understand, as a general rule of thumb, 5500 RPM should gear with 4.10s, 6000 RPM with 4.56s, 6500 with 4.88s, with a stick, if NOT your daily-driver, and if you don't mind 'feeding the SUNOCO man'.
You'll 'max-out' at around 105-110, but you'll get there (IF you hook) VERY QUICKLY.....
