454 radiators
Old Sep 5, 2003 | 08:02 PM
Obdoc's Avatar
Obdoc
Default 454 radiators
During my swap from a 350 to 454, I noticed a difference in the radiators. I just received my 454 radiator and it does not have a place to put a radiator cap! My old radiator had a neck and cap on the passenger side. Is this correct? Does this mean I have to connect an expansion tank? How do I fill the radiator? Any help and pictures would be greatly appreciated. :confused:
Old Sep 5, 2003 | 08:30 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Default Re: 454 radiators (Obdoc)
Yea I think the big blocks used an expansion tank...
Old Sep 5, 2003 | 08:35 PM
rrent's Avatar
rrent
I bought and sold a '64 Ford Galaxie with a 390 some time back -- it had a leaky exp. tank - I called Summit and got on inline tee with a cap on the top. Not correct and something you may want to change -- but should be quick and easy to get some fluid in and get on the road.
good luck
Old Sep 5, 2003 | 08:49 PM
BigBlockVette's Avatar
BigBlockVette
My big block radiator has no cap. I do have the expansion tank with a cap. I fill my system by removing the thermostat and pouring down into the block. I top off the system by filling through the expansion tank. Hope this helps.
Dwayne
Old Sep 5, 2003 | 10:53 PM
bigvette1's Avatar
bigvette1
Default Re: 454 radiators (BigBlockVette)
What year? The 73 and 74's with 454's had filler necks with a cap.
Old Sep 5, 2003 | 11:53 PM
Obdoc's Avatar
Obdoc
Default Re: 454 radiators (bigvette1)
Thanks guys for the info. Sorry, I have a '72. I guess I better start looking for an expansion tank. :cheers:
Old Sep 6, 2003 | 05:39 AM
Larry B.'s Avatar
Larry B.
There are two expansion tanks... One for non-A/C and the other for A/C cars.
Old Sep 6, 2003 | 10:34 AM
Todbo's Avatar
Todbo
Default Re: 454 radiators (bluevetteman)
Becool makes a radiator rated upto 700 HP that only works using the small block radiator support , and has a filler neck. :steering:
To 454 radiators
