1980 corvette engine removal
Old Sep 7, 2003 | 04:18 AM
ITSovr4U's Avatar
ITSovr4U
Default 1980 corvette engine removal
I was told that the engine and trans had to be taken out together, However I refuse to believe this. Can any of you guys give me the facts. I really dont want to remove both. I just want to pull the engine. I have a 99 and never worked on one of these. Thanks, JOHN :conehead :seeya
[Modified by ITSovr4U, 4:20 AM 9/7/2003]
Old Sep 7, 2003 | 07:44 AM
bigvette1's Avatar
bigvette1
Default Re: 1980 corvette engine removal (ITSovr4U)
What trans? If manual the answer is most likely - it is easier to do both and besides give you a change to tune up the clutch assy and throwout bearing.
On an auto - not needed, the alignment dowels work to align fine going back in. This is IMO having pulled both types.
Old Sep 7, 2003 | 11:44 AM
SharkintheWoods's Avatar
SharkintheWoods
Pulled mine out twice by itself. It is an automatic and it was rather an easy process.
Old Sep 7, 2003 | 12:47 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Default Re: 1980 corvette engine removal (SharkintheWoods)
Don't get anymore advice from that person, you can take it out without the tranny.
Just noticed your cam, .580 lift with 224 deg duration ? What rocker arm ration is this, I just bought a CC solid roller and I have to get into the 240's duration to get that lift at 1.5 :1. :D
Old Sep 7, 2003 | 02:29 PM
mapman's Avatar
mapman
Default Re: 1980 corvette engine removal (MotorHead)
Don't get anymore advice from that person, .....
:iagree:
However, on my 1980, I pulled the engine and AT together as both needed repair.
Old Sep 7, 2003 | 02:46 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
You can do it either way.
Old Sep 7, 2003 | 02:49 PM
Oldguard 7's Avatar
Oldguard 7
I have removed the engine from the car without the tranny out of my 79 so many times(for dumb mistakes {buying the wrong flex plate}, deciding on a whim to repaint the engine yellow once I decided blue was ugly, buying a replacemant oil pan) that I can do it in my sleep and I have a 1 car garage with very little space. Will be firing this thing up at the end of next month. I'm on a VERY TIGHT budget. Yes you definitely can pull the engine without the tranny.
[Modified by Oldguard 7, 7:52 PM 9/7/2003]
Old Sep 8, 2003 | 08:45 PM
Marc80's Avatar
Marc80
Remove all the peripherals. Undo the motor mounts. undo the bellhousing bolts. Support the trans on a jack and lift the engine out with a chain and rented hoist. It is pretty EASY to do.
Old Sep 8, 2003 | 09:48 PM
ITSovr4U's Avatar
ITSovr4U
Sorry I did not mention in my sig that my car is 99 c5. That is why the cam is a 224, 581. :rofl:
To 1980 corvette engine removal
