1980 Parking Brake Experts - HELP!
Old Sep 10, 2003 | 10:50 AM
azswede1960's Avatar
azswede1960
Default 1980 Parking Brake Experts - HELP!
I have installed new pads, cables and hardware. Adjusted the pads until I cannot turn wheels, BUT still fail to stop/slow down when tested at slow speed in Neutral. The cable is adjusted all the way and seems really easy to pull back with handle. Am I just not tightening the shoes enough or have I hosed something else up ??
Old Sep 10, 2003 | 12:00 PM
johnnyc's Avatar
johnnyc
Default Re: 1980 Parking Brake Experts - HELP! (azswede1960)
I feel your pain brother. I'll be watching this one.
Old Sep 10, 2003 | 12:09 PM
Mike Ward's Avatar
Mike Ward
C2/C3 parking brakes were cr*p straight from the factory, and they don't get better with age!
Sounds like yours are about average.
Old Sep 10, 2003 | 12:36 PM
jerryp58's Avatar
jerryp58
Are the pads engaging when you pull the handle?
If you have the rear tires off the ground and the e-brake shoes adjusted so the tire will spin, do the shoes engage when the handle is pulled?
If not, sounds like something is not hooked up correctly.
These brakes CAN work. It took quite a bit of adjustment, but mine hold great.
To 1980 Parking Brake Experts - HELP!
