i ordered a new rear storage compartment frame and door bezels for my 74 and got them today :cheers: it appears that the old doors will have to be screwed into the new door bezels, which isn't a problem, my question is about the main frame itself....the old hinges are workable, however, it looks like they are rivited to the old main frame....how should i attach the hinges to the new frame? thanks in advance :cheers:
Looks like your best bet would be to rivet the hinges on there... That's what I would do...
looks like a new rivet gun in my future :) :cheers: thanks oliver :cheers:
When I did mine last winter I tried to repace the rivets with new smash rivets and I could not get them to smash straight. They would smash to one side and I couldn't get them tight. I then used 3/16th pop rivets with some washers and I ended up with a nice job, but it was a lot of work. I also replaced the carpet at the same time. If I had it to do over I would buy the preassembled compartment door set. Craig
I made my own...cut off an end from an air chisel bit , and slightly ground the middle in so it looks like a slight curve. place the flat end of the rivet on a solid piece of metal, put the modified bit in the air chisel, squeeze the trigger, and make sure the tool is square on the rivet...the rivet crushed good. Had a second set of hands holding the piece straight and steady...
