Edelbrock Performance vs. Performace RPM intake ?
Old Sep 15, 2003 | 10:42 AM
setes
4th Gear
Default Edelbrock Performance vs. Performace RPM intake ?
Hi,
I want to install a new intake manifold for my '74 L48,
I don't know what is the difference (power, torque) between Edelbrock's Performer and Perf. RPM
What would you reccomend ?
(I already installed Edelbrock Square-Bore 600 cfm Carburator + custom air cleaner - K&N style)
Paul,
Old Sep 15, 2003 | 11:01 AM
LiveandLetDrive's Avatar
LiveandLetDrive
Default Re: Edelbrock Performance vs. Performace RPM intake ? (setes)
Without a high-rise hood, or a drop base air cleaner, the Performer is going to be your only option. I used it, and it's great. Use the stated RPM ranges to decide which one matches the concept of your engine better. Performer will give you better low end torque, the RPM may sacrifice that for a better high end.
-Chris
[Modified by RUXperienced, 10:03 AM 9/15/2003]
Old Sep 15, 2003 | 11:24 AM
HEARTBEATUSA's Avatar
HEARTBEATUSA
Default Re: Edelbrock Performance vs. Performace RPM intake ? (RUXperienced)
ttt not to take over your thread but I would also like to install a new manifold and carb on my '76 l82 can someone provide model numbers of both items that are basically bolt on? :cheers:
Old Sep 15, 2003 | 12:56 PM
Boofers's Avatar
Boofers
Default Re: Edelbrock Performance vs. Performace RPM intake ? (HEARTBEATUSA)
Good intake - Weiand Action Plus model 8000 or 8004 (one has EGR one doesn't)
Old Sep 15, 2003 | 01:25 PM
Ganey's Avatar
Ganey
You want one that matches your setup. Performer 2101, Action +, or EPS are what you need w/ a mild setup. Probably EPS since you have the "Edelbrock Square-Bore 600 cfm" carb.
Performer 2101 is good for over 400 HP.
Performer RPM 500HP.
Old Sep 15, 2003 | 01:29 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Default Re: Edelbrock Performance vs. Performace RPM intake ? (Ganey)
:withstupid:
Get the one that will be suitable for your setup from what I have learned a RPM Air Gap is closer to a single plane as my dyno numbers are similar between that and Vitor Jr. Would not do too much good on stock or mild setup :D
To Edelbrock Performance vs. Performace RPM intake ?
