Headers with AC question
Old Sep 16, 2003 | 12:55 AM
blunsford's Avatar
blunsford
Default Headers with AC question
My AC bracket on my 73 Vette 454 is mounted to the exhaust manifold. When I install headers, How will I mount my AC compressor? Will the existing bracket work?
BL
Old Sep 16, 2003 | 02:09 AM
Shark Racer's Avatar
Shark Racer
Default Re: Headers with AC question (blunsford)
Not sure what a big block setup is like.
The small block setup has a two-sided stud that goes through the exhaust manifold. When I installed my headers, tsw71 made me a tube-metal spacer which made up the difference in thickness of the header flange and the exhaust manifold.
-Steve
Old Sep 16, 2003 | 02:15 AM
GDaina's Avatar
GDaina
Default Re: Headers with AC question (Pacin'California)
That sounds about right...not that hard to cut 3/8" tubing...that will work...now if the bracket is bolted to the head, there is no need for the spacers. Just have to see where it's bolted down.
Old Sep 16, 2003 | 03:06 AM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
Default Re: Headers with AC question (GDaina)
:iagree: Plus, you may have to grind a larger clearance radius for the header tube.
To Headers with AC question
