Removing computer -- 1981
Old Sep 16, 2003 | 08:42 AM
cicch95's Avatar
cicch95
Finalist 2020 C4 of the Year - Unmodified
Default Removing computer -- 1981
Hello. Asking a question for a friend. A 1981 has a computer to control the carb, etc. Correct? If so, can it be disabled? Therefore using a "normal" carb and manual engine tuning? How would this be done?
Thanks,
-Rick
Old Sep 16, 2003 | 09:01 AM
bigvette1's Avatar
bigvette1
Default Re: Removing computer -- 1981 (cicch95)
Why? It should run pretty well with the ECM and current setup. Unless you start modifying the engine etc, not much will be gained. Let alone the changes may make it unable to pass the emission tests.
Old Sep 16, 2003 | 09:22 AM
Jim Martley2's Avatar
Jim Martley2
Basically all you need a non-computer controled carb. & an older HEI distributor that has a vacuum & centrifical advance.
Old Sep 16, 2003 | 09:48 AM
tersian's Avatar
tersian
Default Re: Removing computer -- 1981 (Jim Martley2)
If you're going to completely remove the computer you will also want to wire in a manual switch for your torque converter if your friend is running an automatic and still has the TH350-C. Honestly, I am not sure if I am going to remove my computer or not, it's so simplistic that it can handle some engine modifications, however, if you start feeding it extreme inputs(radical cams, relocated non-heated oxygen sensor, EGR changes, etc.) I'm not sure how it will react. I'll find out soon enough.
Old Sep 16, 2003 | 10:06 AM
cicch95's Avatar
cicch95
Default Re: Removing computer -- 1981 (bigvette1)
Basically he wants to make some performance modifications. The rochester "quadra-bog" is not the ideal carb for this! Sticking with a computer controlled carb is much more expensive I believe. He is hoping to put a mild cam, headers, a nice intake, and maybe some decent heads also.
-Rick
To Removing computer -- 1981
