3" pipes for a 1970?
Old Sep 16, 2003 | 10:14 AM
JoeRags's Avatar
JoeRags
Default 3" pipes for a 1970?
Does anyone here know of someone who makes a 3" exhaust kit for C3 Vette's? Ive got a 1970 350 4sp, and wanted to upgrade to 3", if I cant find them, who makes a good 2.5" set? Currently I am running Hooker Comp headers with 3" collectors, then reduced down to 2.25"
Any help would be greatly appreciated.
Old Sep 16, 2003 | 10:18 AM
Metal Wulf's Avatar
Metal Wulf
Default Re: 3" pipes for a 1970? (JoeRags)
any good exhaust shop can fab up a set of pipes for you, that would be the best route to go.
bhmyers's Avatar
bhmyers
go with 2 1/2 " pipes. 3" you will have a hard time gettting them through your cross member and keeping them from rattleing if you have a big cam.
Gordonm's Avatar
Gordonm
Nobody makes a 3 inch system. Only a few 2 1/2 inch systems. I had mine custom made and it fits like a dream. You do not need a 3 inch system for a 350. 2 1/2 inch is plenty unless you are spinning it past 7500 rpm and making well over 500 HP. The guy who did mine (he builds exaust for race cars also) said I am good to well over 500 HP. 3 inch is a very tight fit. 2 1/2 is a better choice.
Old Sep 16, 2003 | 11:04 AM
79VetteMike's Avatar
79VetteMike
Default Re: 3" pipes for a 1970? (Gordonm)
:iagree:
Old Sep 16, 2003 | 12:16 PM
JoeRags's Avatar
JoeRags
Who makes a good 2.5" kit, and is it possible to fit an "H" or "X" pipe underneath?
Thanks for all the help.
Joe
Old Sep 16, 2003 | 12:45 PM
Maurice's Avatar
Maurice
Default Re: 3" pipes for a 1970? (Metal Wulf)
:iagree: I had mine done at an exhaust shop. No problems with anything banging around on it.
Old Sep 16, 2003 | 01:49 PM
stingry's Avatar
stingry
St. Jude Donor '05-'06
I had mine (21/2 inch) made up in Ohio at http://www.Stainlessworks.net
They also do other work with 3".
Mine have great sound. Reason I went with these guys is they mandrel CNC bend everything. I also got some "hotrod" style tips which were made out of nice colid stainless steel and polished.
If you cannot find a local shop to make a custom system then I would reccommend these guys. Talkt to Al or Matt.
You will need to order the 2 1/2 inch exhaust mount ($20 from Volunteer Corvette) to bolt up the pipes. THe old brack just will not hold it.
Good luck.
Old Sep 16, 2003 | 01:55 PM
marky mark's Avatar
marky mark
Default Re: 3" pipes for a 1970? (stingry)
Dr. Gass I believe make s a 2&1/2" X pipe. I had mine put in a few inches behind the crossmember. What Gordonm said and also mandrel bends are better, not all shops do it that way though.
Regards, Mark
Old Sep 16, 2003 | 09:39 PM
Ryan77's Avatar
Ryan77
Joe
Either will work, I have the X pipe. There is thread up about X vs H right now, so I'd check that out.
I was also debating on 3" pipe. I have a '77 that I'm dropping a 525hp 383ci into that will redline @6500. I'm not sure if the 2.5 will be enough, I might go 3" or maybe even hooker headers and sidepipes :confused:
[Modified by Ryan77, 9:39 PM 9/16/2003]
To 3" pipes for a 1970?
