Alternator
Old Sep 16, 2003 | 11:40 AM
Jmccreary's Avatar
Jmccreary
Default Alternator
What is the amp rating for alternators in an '80? Is it 61 amp?
Old Sep 16, 2003 | 12:39 PM
baja216's Avatar
baja216
Default Re: Alternator (Jmccreary)
I believe it is 63 amps. :auto:
Old Sep 16, 2003 | 12:42 PM
Crash80's Avatar
Crash80
I believe there were two, depending on your options probably. As I recall one was listed as a 63amp and the other a 70amp. I would over-amp if you are replacing one. It won't hurt anything.
Old Sep 16, 2003 | 02:22 PM
Jmccreary's Avatar
Jmccreary
I just checked and it is stamped 70 amp. I didn't think that they marked them.
Anyway, here is my problem: When the key is turned on and engine is off the battery light comes on bright...which is normal. When I start the car the battery light stays on but is dim. I just had the alternator checked in the car and the result was that everything is normal except the peak amps was low at 39 amps. The tech told me the diode and regulator tested fine. I just read on the internet that a bad diode could cause the amp output to show around 65% of its normal peak rating. So with a 70 amp alternator, 65% of peak would be around 45 amps compared to the 39 peak that it is testing at.
What to you think? Could the diode be bad and the tech's instrument did not properly detect? I called the local Chevrolete dealer and they have a diode for $5. I guess I will get it and put it on.
Old Sep 16, 2003 | 08:47 PM
Boofers's Avatar
Boofers
Jmccreary please post a follow up once you get your new diode pack in, I am interested to know the answer to this one thanks. :thumbs:
Old Sep 17, 2003 | 08:51 AM
Jmccreary's Avatar
Jmccreary
Went to the dealer last night to get the diode. $4.44, one of the cheaper parts I have purchased. Anyway, I had the counter guy double check to make sure the part was for the 70 amp alternator, just to be sure. He comes back and tells me that they ordered the wrong part and the one they had was for the 63 amp alternator. Incompetence at it's finest or just an honest mistake? Whatever the case I am fortunate that I had them double check. Have to pick up what I hope to be the correct part tonight.
Also, I was driving last night and the alternator light went out. Stayed out until after having dinner at the local resturant, went to start it up and it came on again.
Old Sep 17, 2003 | 06:38 PM
Jmccreary's Avatar
Jmccreary
Update: Stopped by the dealer on the way home from work and they had the correct diode waiting for me. I just put it in and the light is no longer on. I guess that fixed it, all for less than the cost of a value meal at the golden arches.
J
Old Sep 17, 2003 | 11:29 PM
Crash80's Avatar
Crash80
Good for you! I love to hear about a happy ending.
To Alternator
