Sway Bar Special
Old Sep 20, 2003 | 01:50 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Default Re: Sway Bar Special (1972 Shark)
I think you'll be better w/the 5/8 bar. The 3/4" may be a little to much.
Old Sep 21, 2003 | 05:14 PM
Tired74's Avatar
Tired74
Default Re: Sway Bar Special (Van Steel)
I am restoring a 74 coupe. I measured my front sway bar at .825" Is it possible it rusted this much. What are the original stock diameters. It is an L48 model with no mod's at all.
Old Sep 21, 2003 | 10:52 PM
CDaniel525's Avatar
CDaniel525
Default Re: Sway Bar Special (Tired74)
Anyone know the stock sway bar for a '74 Coupe with l-48? I want to add one to the rear of my car, but have heard that it may hurt traction for drag racing?? true?
If I do add one, is 3/4" good for the stock one on the front??
Van Steel....im a lil confused...if I order the swar bar off the webpage for $110, it includes everything for the install? The web page doesnt indicate eitherway.
Thanks a lot!
Chris
Old Sep 22, 2003 | 02:24 AM
Titanium Rat's Avatar
Titanium Rat
Default Re: Sway Bar Special (74VETTE)
I dont even go around corners in my vette, would an 1 1/2 front and a 7/8 rear do me good? :jester :jester lol sorry i couldnt resist :lolg:
Old Sep 22, 2003 | 09:14 AM
Van Steel's Avatar
Van Steel
Tired74-
I believe it was a 1" bar
74Vette-
I don't see a problem w/running a sway bar for drag racing. I would think it would tighten up in the rear. Not 100% sure b/c I don't race. Do you want to put a 3/4" bar on the rear w/a stock front sway bar. I don't think that combo is all tha great. If you plan on leaving the front bar alone go w/the 5/8 rear bar.
Yes for $110 you get everything you need. Bushing, brackets, end links.
Old Sep 22, 2003 | 09:44 PM
yppoh's Avatar
yppoh
I am just finishing a 1980 that now has a 350 HO 330HP) and a 700-R4 tricked up by Bowtie. I have no racing aspirations but certainly some "spirited" driving through the hillsides and canyons. This is really for my 16 Year old son, so I'm really praying that I'm right about the racing. Do you still suggest the 5/8 rear bar for this setup as the power is quite different from original?
Old Sep 22, 2003 | 10:34 PM
Zane's Avatar
Zane
I have 18" rims in the back. They have a 5" offset. I had to relocate the parking bracket. Will a rear swar bar from you fit the car with the stock trailing arms?
Old Sep 23, 2003 | 09:54 AM
Van Steel's Avatar
Van Steel
Default Re: Sway Bar Special (yppoh)
Yppoh-
You don't really rate sway bar sizes by horsepower. What size sway bar are you running up front? Stock. If you like taking corners hard and driving the car hard go w/the 3/4" bar. If you like driving like that a lot you may want to step up to the 7/8". If you do step up to this size bar, your definatly going to want to change the front sway bar to at least the 1-1/8"
Zane-
Sway bar will fit on any trailing arm. Stock or offset. With your 18's I'm not sure your going to be able to clear the rim.
[Modified by Van Steel, 9:00 AM 9/23/2003]
Old Sep 28, 2003 | 04:56 PM
Paul L's Avatar
Paul L
I do not have need of your product at this time but I would certainly appreciate your advice. The pic shows a GM FE7 7/16" rear bar that I rebuilt with GM bushings about a year ago. It was intended for my 1979, since sold. The bar now sits in the basement. I now have a 1967 SB 327 with a stock 3/4" front bar. I was thinking of adding that 7/16" rear bar. (The frame weld nuts are in place.) Do you see any advantages/disadvantages of such an install? My driving is not terribly spirited but if I can use that rear bar I would like to do so.
Old Sep 28, 2003 | 08:33 PM
Rogue Wave's Avatar
Rogue Wave
CI 4-5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-16-'17
I've got a 73 that did not have a rear sway bar and was looking at getting one. What better time than now. :yesnod:
Just put in an order for a 5/8" rear. :thumbs:
Thanks... :cheers:
Old Sep 29, 2003 | 12:49 PM
Zack Wenning's Avatar
Zack Wenning
I jsut placed my order for a 1 1/8 front and 5/8 rear bar. Thank you Van steel and everyone else who responded.
I cant wait to corner as flat as my brothers 85 with Z51 :cheers:
Old Sep 29, 2003 | 01:17 PM
Van Steel's Avatar
Van Steel
Default Re: Sway Bar Special (paul67)
paul67
Put the bar on your car. I think you will enjoy the ride much more after the 1st turn you make. The bar will work just fine.
To All that placed your orders for sway bars I would just like to say thank you. Your business is appreciated.
Next to come is Slotted rotors for $110 each. Normal price is $139.99 :thumbs:
Old Sep 29, 2003 | 03:46 PM
  #33
Paul L's Avatar
Paul L
Thanks. I appreciate your reply!
Old Sep 30, 2003 | 12:23 AM
  #34
blunsford's Avatar
blunsford
I have a stock rear sway bar that shows some wear and the bushings are half shot. When do you need to replace the bar and when do you just replace the bushings?
I have a 73 with a BB 454. IF you recommend replacing the bar, what size do you recommend?
Old Oct 1, 2003 | 08:54 AM
  #35
Van Steel's Avatar
Van Steel
Default Re: Sway Bar Special (blunsford)
You don't need to replace your sway bar unless it's bent or rusted through. Bushings you can get anywhere and are very easy to replace. If you did want to get new sway bars I will nee to know how your driving habits are in order to give you any kind of recommendation. Do you like to drive your vette hard and corner hard or do you just cruise around town?
Old Oct 3, 2003 | 09:06 AM
  #36
Blackened 79's Avatar
Blackened 79
Just recieved my 3/4" Rear kit...the bushings are maroon !???? can I exchange them for black ?
Old Oct 3, 2003 | 03:02 PM
  #37
Van Steel's Avatar
Van Steel
Default Re: Sway Bar Special (Troublemaker 71)
Yes I just e-mailed you. I don't know how or why they put maroon bushings in there. I will send you black replacements A.S.A.P.
Dan
