850DP adjusted, Thank you!
Old Sep 21, 2003 | 11:46 AM
Bob Turner's Avatar
Bob Turner
Default Re: 850DP adjusted, Thank you! (427Hotrod)
427Hotrod,
I appreciate the info. I was using the info from 467Ratman and LAvette as a baseline to get my Demon 850 dialed in.
The fact that there are #85's in the primaries on the Demon from the factory, and the fact that 467 Ratman is using a #76-78 in the primaries of his Holley tells me that my carb is probably running way too rich...
So much to learn on these carbs. I am glad I am finally starting to!!
Bob :cheers:
Old Sep 22, 2003 | 02:53 PM
Bob Turner's Avatar
Bob Turner
Default Re: 850DP adjusted, Thank you! (LAvetteman)
LAvetteman,
Are you runing a double pumper or vacuum secondaries in your Demon 850?
Thanks!
Bob :cheers:
