Guages, mechanical or electric why?
Old Sep 20, 2003 | 10:09 AM
ImBatman's Avatar
ImBatman
Default Guages, mechanical or electric why?
Getting ready to buy the 2 1\8 guages. fuel, wtr temp, Oil, volt, oil temp or vac or fuel pres not sure which one of these 3.
What do you guys recommend for replacing the clock.?
Also what type guage mechanical or Electric?
Probably going with the Autometer pro Comp's because they are the only nice looking black face guages I see. Thought's on these?
Old Sep 20, 2003 | 11:02 AM
Cookwithvette's Avatar
Cookwithvette
Default Re: Guages, mechanical or electric why? (BlackRat)
No doubt... go electric.
Electric temp gauges are more accurate and electric pressure gauges don't have the hazard of pressurized lines running around. (and into the passanger compartment)
Old Sep 20, 2003 | 11:05 AM
GDaina's Avatar
GDaina
The only one that's mechanicl that you would replace would be the oil pressure gague. I never was thrilled with the dinky nylon tubing the factory used.
I'm not sure if the Autometer's water temp is calibrated to the factory sending unit. Do they provide a sending unit with the gague?
Old Sep 20, 2003 | 11:14 AM
ImBatman's Avatar
ImBatman
Default Re: Guages, mechanical or electric why? (GDaina)
Thanks guys. Electric is what I figured I would go with but wanted to get some other opinions first. I had one of those nylon tubes brake on me before and it destroyed the carpet in an old NOVA I had. :mad
What guage would do me the most good for replacing the clock. I'm thinking oil temp. :confused:
Wade
Old Sep 20, 2003 | 11:19 AM
Corey_68's Avatar
Corey_68
Wade
I went with an oil temp gauge to replace my clock, all mine are Autometers. Also the gauges are 2 1/16 not 2 1/8, that is if you want to use the same gauge panel.
:cheers:
[Modified by Corey 68, 10:28 AM 9/20/2003]
Old Sep 20, 2003 | 11:23 AM
GDaina's Avatar
GDaina
Oil temp is good, will give you a better indication than water temp, though the two work hand in hand...think the optimal oil temp is 240 degrees. If oil temp starts to climb, you know right away something is not right. When the temp reaches the 280-290 degree mark, you be in a heap o trouble, boss.
Old Sep 20, 2003 | 11:26 AM
ImBatman's Avatar
ImBatman
Thanks guys. placing the order today. Corey, you are right 2 1\16th not 1\8. Typing faster than I was thinking which isn't to hard... :crazy: :smash: :lol:
wade
Old Sep 20, 2003 | 04:22 PM
LAvetteman's Avatar
LAvetteman
St. Jude Contributor
Default Re: Guages, mechanical or electric why? (Cookwithvette)
I always thought mechanical water temp gauges were more acurate. Now all others I agree, go electric.
Old Sep 21, 2003 | 01:23 PM
spikezz4's Avatar
spikezz4
BlackRat, you might consider replacing the clock guage with a 270 sweep guage wired to a 3 or 4 position switch. You could easily switch between Oil Temp, Transmission Temp, Power Steering Fluid Temp, or Rear Diff Temp. Just takes a few more sensors wired back to the guage/switch. You will need some imagination to label it.
Spike
To Guages, mechanical or electric why?
