Rear Spring Alignment
Old Sep 20, 2003 | 10:12 PM
Dk Met Grn 80 L82's Avatar
Dk Met Grn 80 L82
Default Rear Spring Alignment
When I change the rear spring, do I need an alignment?
Old Sep 20, 2003 | 10:20 PM
Mike Ward's Avatar
Mike Ward
Default Re: Rear Spring Alignment (Dk Met Grn 80 L82)
No.
phxraptor's Avatar
phxraptor
:yesnod: Any time you change the ride height you should check the alignment. :cheers: :seeya
Old Sep 20, 2003 | 11:06 PM
Shark Racer's Avatar
Shark Racer
Default Re: Rear Spring Alignment (phxraptor)
Thus, if you change the rear spring but maintain the original ride height, alignment will be fine. :)
Old Sep 20, 2003 | 11:22 PM
PatG's Avatar
PatG
I just put a fiberglass spring on my car and it wants to pull to the left. I'm gonna have to get it aligned. So in my experience the answer is yes.
Old Sep 21, 2003 | 10:46 PM
Dk Met Grn 80 L82
Default Re: Rear Spring Alignment (PatG)
I plan to keep the ride height the same, or at least the same as it should be. Right now one side sits 0.5 inch lower than the other. So hopefully alignment should be fine after spring change. :chevy
To Rear Spring Alignment
