Muncie servicing
Old Sep 21, 2003 | 11:29 PM
Red69's Avatar
Red69
Default Muncie servicing
How would one go about servicing a Muncie? I know that there is a drain plug, but its on the side… not on the bottom like an oil pan…?? Or should it just be pulled and inspected, then refilled while its on the bench?
:withstupid:
Old Sep 22, 2003 | 12:33 AM
LAvetteman's Avatar
LAvetteman
St. Jude Contributor
Default Re: Muncie servicing (Red69)
If you have no drain plug than the same procedure for servicing the differential should be followed. Suck the old stuff out and refill with 80/90w gear oil. :thumbs:
Old Sep 22, 2003 | 08:02 AM
GTR1999's Avatar
GTR1999
What do you wnat to do with it? Does it work ok? if so then just changing the oil is all you need. I run 90 wt gear oil in my manuals I don't care for the syn stuff. If you pull the tranny then buy the video that 5speed.com sells for rebuilding Munices. It will walk you through a complete rebuild and anwser most questons you have. It's a great reference tool too if you just want to know what's in there.
Gary
To Muncie servicing
