Best header coating?
Old Sep 23, 2003 | 12:10 AM
396 RAT's Avatar
396 RAT
Default Best header coating?
Is Jet Hot still the way to go?
Or are others just as good / better?
:smash: :smash: :smash:
Old Sep 23, 2003 | 12:24 AM
GDaina's Avatar
GDaina
Default Re: Best header coating? (396 RAT)
Jet Hot is good, but I've heard it's not permanent. Also heard if you spill oil on the surface it will discolor. Hang tight, the guys that have Jet Hot will give you better guidance
Old Sep 23, 2003 | 12:35 AM
396 RAT's Avatar
396 RAT
Default Re: Best header coating? (GDaina)
Plan to go Black, or Cast.
(if this hepls)
Old Sep 23, 2003 | 08:04 AM
James's Avatar
James
I had a set headers coated by Jet Hot about 10 years ago and I had problems with rust after one season. I never even drove the car in the rain!!
I sent them to a company called High Performance Coatings in Bluffdale Utah and had them recoat them. This coating has lasted since then. I just had them coat a set of Hooker headers and side tubes for my 69 big block in Black. They look real nice I must say. http://www.hpcoatings.com
[Modified by James, 7:05 AM 9/23/2003]
Old Sep 23, 2003 | 08:27 AM
ImBatman's Avatar
ImBatman
Default Re: Best header coating? (James)
Check out Air Born coatings. I talked to one of the reps at a show here in Charlotte NC and was impressed with them. They had examples both on and off the of vehicles. Full inside outside coating for headers is about $220. There warranty is a complete redo of the entire peice if you have chipping or rust through. They are probably who I am going with. They do have a web site.
:cheers:
Wade
Old Sep 23, 2003 | 09:47 AM
cicch95's Avatar
cicch95
Finalist 2020 C4 of the Year - Unmodified
Default Re: Best header coating? (BlackRat)
Check out AirBorn coatings
:iagree: AirBorn does great work. Had my headers done for the Chevelle almost 4 years ago. Still no rust. Still look great. They are a professional outfit and great to work with.
-Rick
Old Sep 23, 2003 | 02:01 PM
396 RAT's Avatar
396 RAT
Default Re: Best header coating? (cicch95)
Thanks for the info!
Are there any coating co's here in Ca.?
Would rather not ship, but may have to...............
To Best header coating?
