help me drop the diff. crossmember
Old Sep 24, 2003 | 07:06 PM
YankeeStation1967's Avatar
YankeeStation1967
Default help me drop the diff. crossmember
delete pics
Old Sep 24, 2003 | 07:11 PM
dewcustom's Avatar
dewcustom
Default Re: help me drop the diff. crossmember (Ed T)
first unbolt everything and then use a wedge (like for splitting wood) between the fram and crossmember if yours is like mine was than no amount of prying will ever work
Old Sep 24, 2003 | 09:14 PM
CF6873's Avatar
CF6873
I used a 6' digging iron to pry mine apart. It was no picnic. I think I recall some guys on the forum saying they used a gear puller to pull it apart. Good Luck, Craig
Old Sep 24, 2003 | 09:17 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: help me drop the diff. crossmember (CF6873)
Drop the whole differential with the beam on it, that way you can pull the beam and have leverage to control the diff wilst supporting it with a jack. Some helpers would be really handy. Also, this would be a good chance to replace (if worn) the mounts or replace w/ solid bushings.. and clean up the crossmember.
Old Sep 24, 2003 | 09:30 PM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
I used a splitting wedge and a pickle fork along with a 3lb. maul. I used the pickle fork to get it wide enough to drive in the wedge, and then started hammering on the wedge. I a floor jack right under the center chunk my old exhaust pipes still in place, so when one side popped loose it didn't drop far until it contacted the jack and the pipes. I had some old dog blankets over the pipes to cushion the fall.
It only dropped about 2 inches, then I went to the other side and started pounding. I was hitting the end of the wedge so hard, my wife thought I was destroying the car.
I have also read that heat applied to the center of the mounts will help free them also.
I agree that no amount of prying with a prybar will get it out if you just try to use leverage and your weight, I had a 4 foor prybar and I put my full 250 on it and the crossmember wouldn't budge!
Old Sep 24, 2003 | 10:10 PM
69ttop502's Avatar
69ttop502
Ed, use a 5 or 6 inch 2 jaw gear puller. Just loosen the bolts a little to catch the crossmember when it drops and run the puller bolt onto the crossmember bolt. Literally got mine out in 5 minutes this way.
Old Sep 24, 2003 | 11:22 PM
GATOR454's Avatar
GATOR454
I removed mine just last week. I supported the dif. with a jack and used a pickle fork to wedge it apart. Not by prying it apart but by driving the fork in along the side of the joint a little ways then pulling down then driving it in along the other side and then pulling down. It released after the second try on the first side and after the fourth try on the second side (probably because it was at a slight angle). I think I would rather try the gear puller meathod as it was a bit of a suprise when it did turn loose.
Here is a link to a picture album with pictures of this joint
The first is a pic of the ball part of the joint. Notice the vertical scaring on the joint. To my belief it has only been off this one time, and since there is no travel in the joint it happened when it went on or when it came off. So it is tight.
The second picture was a mistake I photograghed the wrong side.
The third is the socket part of the joint. It is all rubber inside.
The link:
Also, be aware that to replace 1 rubber bushing is about $140
Hope this shed some light,
David
[Modified by GATOR454, 11:41 PM 9/24/2003]
[Modified by GATOR454, 11:44 PM 9/24/2003]
Old Sep 25, 2003 | 12:05 AM
Zack Wenning's Avatar
Zack Wenning
Default Re: help me drop the diff. crossmember (69ttop502)
This was the only way that worked for me....I tried for hours with different wedges/prybars, but then i tried the gear puller and it popped right out.
Old Sep 25, 2003 | 10:45 AM
moosie982's Avatar
moosie982
Hey Ed, Good luck with that crossmember, let me know if you need any help :yesnod: . Did you go to C. E. Mills last saturday, any bargains ? The trip to Newark was an eye opener for my honey, she freaked at the traffic and drivers, changed her mind and cancelled the class. Bye, Peace,,,,,,,,,Craig :seeya
Old Sep 25, 2003 | 07:21 PM
NHvette's Avatar
NHvette
I pried mine off with a 3ft pipe. I like the gear puller idea.
The rubber bushing just gets stuck to the steel 'tophat'.
Suction cup action plays into it, too - I think.
Definitely leave the bolts in loose (a few turns) to catch it from crashing down.
:seeya
Old Sep 25, 2003 | 07:40 PM
foundvettelifeisgood's Avatar
Default Re: help me drop the diff. crossmember (NHvette)
My brother and I used a 4' pry bar. It's not the force, but the angle that is the trick. The weight of the differential brings it down, once you pry at the proper angle. The crossmember/dif combo wants to fall back and down towards the rear of the car. As others have said, leave the bolts in place loose and a jack a couple inches below the dif to catch it.
It's really not that hard, especially compared to lower shock mount removal.
The scary part is removing the 4 bolts that hold the crossmember to the dif. Soak them good overnight. If you strip them, you're screwed.
:smash: :smash: :smash:
Old Sep 25, 2003 | 09:11 PM
I got a torch but I wont be using it anywhere my new paint job!!
...or near the gas tank, which is inches from these 4 bolts. :lol: Please don't light that torch.
The car looks great. :cheers:
Old Sep 27, 2003 | 04:51 PM
Congrats! Fun stuff. :smash: :smash: :smash: :cheers: :party:
Old Sep 27, 2003 | 05:08 PM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Good job....nice to see a follow up and with pic's yet. :cool:
All too often questions are asked and answered yet we never find out how it all turned out...let alone get a thank you.
To help me drop the diff. crossmember
