18" WHEELS
Old Sep 25, 2003 | 12:20 AM
Oldguard 7's Avatar
Oldguard 7
Default 18" WHEELS
I recently read in a post about 18" wheels will clear the parking brake assembly. How many are using 18" wheels. If you have pics please post. I too will search for any posts or pictures.
Old Sep 25, 2003 | 01:06 AM
Zane's Avatar
Zane
Default Re: 18" WHEELS (Oldguard 7)
My 18" rims did not clear with the 5" offset. Relocated the bracket to the top of the swing arm. Used to have 17" but they just touched the leaf spring. 18" solved the leaf spring problem. If you have a rear sway bar that might be a problem.
Old Sep 25, 2003 | 09:07 AM
70 LS1's Avatar
70 LS1
I have 18" rears with 4.75" backspacing. They clear the bracket, but rub on the cable just in front of the bracket. I don't care because I am removing the entire parking brake assembly including cables and brackets.
Old Sep 25, 2003 | 09:24 AM
81' Corvette Guy's Avatar
81' Corvette Guy
Default Re: 18" WHEELS (70 LS1)
70LS1: your removing the cable/bracket all together..or just relocating them. If your removing what are you going to use to replace the system?
Thanks..Joe..peace <*)))>< :auto:
Old Sep 25, 2003 | 09:28 AM
70 LS1's Avatar
70 LS1
Default Re: 18" WHEELS (81' Corvette Guy)
As of now, I am just ripping it all out. The parking brake provisions of the C5 rotors is way to large for the C3 system. I am looking into the possibility of using a SSBC parking brake. They sell a very small caliper that is cable operated that mounts on your rotor.
To 18" WHEELS
