Power Steering
Old Sep 25, 2003 | 12:55 PM
Dk Met Grn 80 L82's Avatar
Dk Met Grn 80 L82
Default Power Steering
My PS control valve is leaking. Should I replace with a rebuilt and return my original as a core? or Buy new and keep the original with other original parts box for the future? Also should I go ahead and replace the PS cylinder at the same time? New/Rebuilt? Hoses were done last year. Can I do this with a basic socket and wrench set on ramps?
Old Sep 25, 2003 | 06:02 PM
MIKER's Avatar
MIKER
Default Re: Power Steering (Dk Met Grn 80 L82)
I successfully rebuilt mine and the kit was very inexpensive. It believe it to be a project that most anyone could do. For detailed information search the CF archives or check out http://www.corvetteFAQ.com
I cannot see a reason to replace the PS cylinder if it is not leaking. Spend money on broken stuff!
Old Sep 25, 2003 | 11:23 PM
Dk Met Grn 80 L82
Default Re: Power Steering (MIKER)
Thanks MIKER. I'll check out that link.
Old Sep 26, 2003 | 12:31 PM
mvftw's Avatar
mvftw
I also have to replace mine. I was going to get the rebuilt units from ZIP ($200) includes 4 new hoses and rebuilt valve & ram. I don't mind to rebuilt it myself, but I heard that the valve has to be centered. The rebuilt units are already centered. Did you have trouble centering yours? I also like to keep my factory parts but this could be an exception...
Old Sep 26, 2003 | 10:34 PM
MIKER's Avatar
MIKER
Default Re: Power Steering (mvftw)
...Did you have trouble centering yours?...
Actually, I got lucky and it did not require any adjustment after re-installation!?! :confused: :thumbs: but the procedure appears to be very simple.
$200 sounds like a fair price for all of the parts you listed! :yesnod:
Old Sep 27, 2003 | 11:35 AM
adamdinat's Avatar
adamdinat
I used a rebuilt controller. My main concern was time and getting the job done once. One fear was that after rebuilding the thing would still leak. If you have the time and paitence fiddle with it go for the kit.
Old Sep 27, 2003 | 08:24 PM
Dk Met Grn 80 L82
Default Re: Power Steering (adamdinat)
I'm leaning towards a rebuilt one. I read some previous posts that were saying that there seems to be more problems with the new ones not holding up (1yr leak).
To Power Steering
