Choosing Coil overs?
They also come in 300/100 down to 100/50.
The combinations are enless.
What do I look for in a rear coil over? I can also get 2 1/4 and 2 1/2 springs in any weight?
All this is confussing. I want to order a set but wouldn't have a clue.
Can you guys teach me what I want?
Now, if I didn't know any better, I'd be thinkin' you want to see who the knowledgeable ones are, who can pass the suspension test.
Well, it ain't me bud, not into the radical suspension changes, but your thread has peaked my interest to know the answer to the quiz. I suspect only a handful will be able to pass. :D
Since I will be spending about $500 or so for a set of coil overs I want to make an educated selection.
I would probably pick Bilstein because that is a name I reconize but the valving I don't have a clue.
I do have a good source but I haven't called him yet. I would like to be able to discuss it with him while he give me advice.
Here is a link that will give you information on what you will need to know to chose the correct ones. http://www.proshocks.com/ Look at their street shock tech and calculators.
[Modified by Pete79L82, 8:36 PM 9/25/2003]
second off how would the handling be differant vs the plastic spring I have now??? in general that is...of course.....
any advantage to coil overs for the front wityh my stock arms?? or is that all just not worth any more messing with??? and isn't the stock arrangement essentially a coil over anyway??? except may weight???
still want a taller spindel....I"m wondering is a longer stemmed balljoint can be found....it's not the welding of the spindle that bothers me per-se, it's the positioning of the parts, and so forth....Norval???
GENE
Because the physical size of a C/O is smaller it is easier to place them closer the the centerline of the tire. The closer it is mounted to the tire centerine the more effective it is. If you mount the C/O in the same location as the stock spring and shock(as in the front spring) then there is no perfomance befitis gained other than weight. If you mount them is the same position as the rear shock then the shock performance would be the same as a non-C/O but the spring would be slightly less effective because the lower mounting point would be farther inboard then the stock spring. The main benifit in the rear would be that you would have a much larger selection of spring choices than with a leaf. It is also considerably easier to change a C/O spring than a leaf spring. You also have the added benifit of ride height adjustability.
Pete
[Modified by Pete79L82, 7:23 AM 9/26/2003]
I am leaning towards digressive shocks. As you know and some might not a digressive shock has alot of resistance to movement right away. A Linear shock moves easy at first then gets stiffer with more movement.
Shocks are rated in inches per second of movement.
Move a linear shock 1 inch per second and it has little resistance, eg 30 pounds for 1 inch. Move it 2 inches per second and it's resistance is 60 pounds etc, etc.
Move a digressive shock 1 inch per second and it might be 150 pounds for the 1st inch but move it 2 inches per second and it might only be 175 pounds.
The linear shock constantly increases the resistance while the digressive shock tops a peak quickly and stays the same from then on.
3 things require a shock, bumps, dive and roll. For a bump you want a softer shock that increases with the severity of the bump. For dive as in braking it would be nice to have a fast acting shock to prevent dive like digressive, the same with roll, we want to resist the roll so a digressvie shock with it's high initial resistance prevents roll.
The digressive shock if pushed too hard will not respond with increased pressure while the linear shock responds by increasing pressure the harder you push it.
A popular setup is linear front, digressive back.
Pete what is a 50/50 split? If you have a true 50/50 split the shock moves in and out at the same rate but what about the spring? It is resisting the shock moving in by #200 plus pounds per inch while pushing the shock out with the same force.
I want a soft compression like a #4 but a harder rebound or pull out of #6
I will seriously consider Pro Shock if you recommend them.
I want the 2.5 springs as long as the OD is not over 3.5 inches.
I too do not want a adjustable shock as I wouldn't have a clue as to what I am doing.
The compressed length and extended length is easily measured by knowing the installed height and make it about in the center of the shocks travel.
Thanks again Pete for taking the time and last night Pete measured roll centers with a stock spindle and a 2 inch extended spindle. It took alot of his time to measure and calculate the roll centers but it confirmed to me that I made a good guestimate at 1.5 inches longer spindle.
We have about 3.5 inches between the swing arm and the fiberglass wells. The shock with the coil needs to be centered in this space so I will remove the upper shock mount, reinforce the front and underside of the frame with 1/8th plate and add a new upper mount that points straight down and not one that binds the top mount like the stock one would.
For a lower mount I will weld it to the OUTSIDE of the trailing arm between the arm and rotor and have is sweep under the trailing arm and end up flush with the inside of the trailing arm. This will allow the shock to hang straight down in the allowed space.
As for welding the spindles mine are done, painted and waiting to be installed. I built a jig to hold the spindle in alignment so welding was not a problem.
It will totally destroy my pump steer settings so I will have to go through that again. It is not hard the second time around since you know what you are doing.
Here's the front coil over mounted on a modified STOCK A-arm.
Another shot.
And another.
Rear coil over in place, notice the Offset TA's.
Here's the stock trailing arms modified to accommodate the coil overs.
The kit.
Rear CO in place.
Rear coil overs in a 80 vette.
Last shot.
I'm no expert about the coil over set ups, but what I've read about them is that the adjustability goes beyond normal coils and shock or shock and leaf spring. They are more compact in size and will provide suitable ride feel for almost any kinda driving. :steering:
:steering:
[Modified by groovyjay, 9:18 AM 9/26/2003]
If I were to go to coil overs (and I'm certain I will but not those 650+$ konis) I will get some spherical end ones because they give no deflection and I don't drive a lot anyway (hell, not 1 mile in the last 2 years :) )
About the koni's, the ones pictured above are 8212 double adjustable aluminum. There's 8211 too, single adjustable aluminium and 8112 is single adjustable steel body.
Most of the 8212 shocks you see available are SPA1, those are 90/10 (well not really) valved for drag application. Those are a lot cheaper than the ones you'd need for a street/slalom setup.
I an going with Digressive shocks because they have a very high resistance right off the bad, up to 3 times more then a linear shock so they resist pitch as in braking and roll and is leaning in corners really quickly but they loose resistance as the travel goes up like over a severe bump so they are softer under hard usage.
I am going to start with 200 pound springs so for a shock I will choose 300 pounds on pull out and 100 pounds compressing. I am using the 200 pound spring to resist compression so the shock should with the help of the spring act like a 50/50 shock. Equal pressure in or out, again like Pete suggested.
The car went away today because I am anxious to get started on modifications.
I did look at the rear upper shock mount and I am convinced the stock shock mount will not work. Beside being crooked so it would bind the upper mount it is mounted to the rear of the frame pushing the shock towards the wells. The shock needs to be centered between the trailing arm and well so I will install a new reinforced centered upper mount and weld a mount on the trailing arm.
Monday I will try to order my coil overs and springs. I also want the long travel 14 inch 2.5 diameter springs.
The length of the shock will be 10.5 compressed and about 17 inch extended. The working height hopefully will be in the center of the shocks range.
Anyone find flaws in my reasoning? Speak up now before I spend $500-$600.
I've been looking at the pro shocks too, also looking at afco and QA1, don't know what to choose. Does anyone have the price list on those Pro Shock ones? I want threaded bodies, not a standard shock with a sleeve.
[Modified by Twin_Turbo, 5:53 AM 9/28/2003]
I don't have a price on the ones I want but Pro shock, aluminum, full threaded body, digressvie about $132 AM. The ones I want are actually gold anodized, threaded only the bottom half, gas with a set compression #2-#6, I will choose #3 for soft with a complete adjustable rebound which I will set fairly stiff or #6.
I will phone Monday for prices. As for springs I think #200 are a little light but I will start there and work up. I would rather be too soft then too hard. I would also like the 14 inch long springs so they have lots of travel. Ideally I want my rear to use most of it's travel in normal high speed driving. I don't want it locked down with stiff springs.
I am counting on the digressive shocks to keep it from squating off the line, not stiff springs.
The pics from groovyjay are those pics from ACP Germany and they use the stock upper mount for the coil overs.
[Modified by Twin_Turbo, 10:21 AM 9/28/2003]
