Computerized Corvettes (1982) Questions
How reliable are these systems, or are they something that I should avoid since there are plenty of other years to choose from....
thx
The fact of the matter is electronic fuel injection is more efficient, easier to maintain and dramatically reduces emissions. The downside is that is requires computer aptitutde, additional diagnostic equipment and for the average backyard mechanic...more patience.
While I've got a 78...I also had a 90. Once I picked up the diagnostic tool...it was a breeze to maintain and diagnose problems. Can't say I've done an 82 which was the first for Corvette.
Bottom line...if those are the years you like...don't let the electronics shy you away
The other 49 states, and exports, got the RPO L48 or L82 engines, 350 c.i., carried over virtually unchanged from 1979, with the regular mechanical 4-bbl Q-jet. The L48 was rated at 190 HP, while the L82 claimed 230 HP.
If you bought the LG4 in 1980, you were given a $50 credit on the base price, as compared to the 49-state L48 car. :)
For the 1981 model year, the "CCC" system was applied to what was essentially the L48 engine, now called the L81. With minimal changes, the CCC allowed the larger 350 to meet California's more stringent emissions requirements that could only be met a year earlier by the smaller 305 engine. There were 40,606 of these cars built, all rated at 190 HP. It should be noted, however, that there were still minor differences in the cars built for sale in California, and those cars required separate certification for California emissions.
In performance terms, however, the L81 suffers from one serious problem that the engineers either overlooked or chose to ignore when they adapted the LG4's CCC to the larger 350 c.i. engine: the exhaust manifolds. These are welded tubular pieces, made from stainless steel; two characteristics which have the nice properties of being lighter than cast iron and very durable. Problem is, they're way too damned small. With the rather sharp corner bends, their internal diameter is only about 1 3/8", while most performance gurus agree that the 350 needs 1 5/8" primary tube headers to make power at 5,000 rpm and above.
For 1982, the E4ME carb gave way to a pair of throttle bodies mounted on a cross-ram style manifold. GM called this the "CrossFire" engine. The CCC system was still in place, now controlling the throttle bodies at all speeds, unlike the '81 version which only controlled mixture on the primary half of the carburetor, and only at part throttle. The computer chip for the '82 was upgraded, and now made adjustments to fuel mixture 80 times per second. There were 25,407 of these cars built, claiming 200 HP.
The 1983-***-1984 model used the "CrossFire" engine and CCC system carried over from '82, with only minor changes allowing the claimed horsepower increase from 200 to 205. The well-known performance problem with the CrossFire is the very poor port matching between the intake manifold and the cylinder heads, compounded by the somewhat small cross section and tight corners in the runners.
Aren't you glad you asked? :D
Now that it is straightened out, it runs great!!!
If you do get a computerized car, do make sure that anyone you have
work on, knows and understands the Crossfire system.
It could be a little tricky at times. :yesnod:
