Deciphering alternator codes
Old Sep 26, 2003 | 11:06 AM
ettev's Avatar
ettev
Default Deciphering alternator codes
What is the correct method to determine production dates for C3 alternators. I understand the month having a corresponding "alpha" code, but what about the numbers before and after the month letter? Which signifies the year, and which signifies the day of the month?
My alternator code is "7D1". It's probably not original to my '70, but what do these numbers tell me? April production of 1967/1977 on April 1st, or production on April 7th of 1971/1981?
Old Sep 26, 2003 | 11:24 AM
HEARTBEATUSA's Avatar
HEARTBEATUSA
Default Re: Deciphering alternator codes (ettev)
"April production of 1967/1977 on april 1st," according to my book your correct in how you read the code but I can't tell if was '67 or 77 either :confused:
Old Sep 26, 2003 | 11:38 AM
stpman's Avatar
stpman
Default Re: Deciphering alternator codes (HEARTBEATUSA)
If it was built April 1st 1967 it would be an externally regulated unit. if it has the regulator inside (flat plug vs square plug) it wouldn't have been built in '67. '69 (I believe) was the 1st year for internal regulated altenator.
Steve :steering:
[Modified by stpman, 11:39 AM 9/26/2003]
Old Sep 26, 2003 | 11:39 AM
ettev's Avatar
ettev
It's probably 1977. I believe '67's used external voltage regulators. My car has no signs of one of those.
Old Sep 26, 2003 | 11:40 AM
ettev's Avatar
ettev
Default Re: Deciphering alternator codes (stpman)
Steve: You picked up on that a minute before me! :D
To Deciphering alternator codes
