Flares VS Wheel Size
Old Sep 26, 2003 | 02:47 PM
Shark Attack's Avatar
Shark Attack
Default Flares VS Wheel Size
I am finding myself more inclined to flare my future vette in front and rear. What size wheels will then be able to fit under the car? Please include the backspace also, IE: 15x10 W/5"BS Thanks
JB
Old Sep 26, 2003 | 05:13 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: Flares VS Wheel Size (Shark Attack)
The 10" is the rim width but that does not include the lip on the end, usually the lip is 1/4 an inch on both sides, making the wheel a trye 10,5" wheel rim edge to rim edge. With 5" backspacing that means it has 1/4" pos. offset
That means that 5,5" of the wheel is outboard, that's 1,5" more than stock (stock wheel is 8"wide but w/ rim edges taken into account it's actually 8,5" and the offset is 1/4"pos, the mouting flange is dead in the middle of the tire so when you don't take the rim edge in account it's 0 offset)
So, you'll need about a 1,5 to 2" flare
Old Sep 26, 2003 | 05:19 PM
Shark Attack
Default Re: Flares VS Wheel Size (Twin_Turbo)
I think I need to clarify, If I use the ZL1 fender flares, how wide of a rim/tire can I use.
Old Sep 26, 2003 | 05:21 PM
Twin_Turbo's Avatar
Twin_Turbo
How wide are ZL flares? 2" I think they come in 2 and 3,5"if I'm not mistaking. With a 2" flare you'd be able to run the above wheel.
Old Sep 26, 2003 | 05:29 PM
Shark Attack
cool thanks
Old Sep 26, 2003 | 08:49 PM
groovyjay's Avatar
groovyjay
Merlin522 was using 14" wide rear wheels on his 74 'vert. He was also using the Eckler's style flares all around. I think the rear tires were 345/35/19 and fronts were 295/40/19. Backspacing was stock all around. I'm running 20x10 rear wheels with 285/30/20 tires tucked under the stock body lines... :cheers:
Old Sep 26, 2003 | 09:20 PM
Deslok's Avatar
Deslok
Check out Chris's 69....
http://www.mcspeed.homestead.com/About_Us.html
With ZL1 flares and offset trailing arms, he has 18x12(R) with 335/30 tires.
Beautiful vette for sure.
Keith
[Modified by Deslok, 8:21 PM 9/26/2003]
To Flares VS Wheel Size
