ticking noise
Old Sep 29, 2003 | 05:51 PM
ray77vette's Avatar
ray77vette
Default ticking noise
ever since i bought my 77 i have had a slight clicking noise. lately the noise has gotten worse. the noise seems to be coming from the front of the engine and ticking rate goes up with the RPMs. i at first thought the fan was hitting the shroud but it spins freely when moved by hand. is it possible the fan cluth is causing this problem. also i have removed the A/C belt to see if that could be the problem, but the noise is still there.
thanks
ray
Old Sep 29, 2003 | 06:12 PM
79Corvette02's Avatar
79Corvette02
Default Re: ticking noise (ray77vette)
It could be your water pump, signaling its about to fail, or it could be your rocker arms making the ticking noise if they're sticking/binding, etc... You can take off the valve covers and have a look for signs of binding or interference. :cheers:
Old Sep 29, 2003 | 06:15 PM
Fevre's Avatar
Fevre
Possibly a exhause leak at the manifold and head, a loose rocker arm or a bad lifter. Check for the exhaust leak first by taking a 1 to 2' section of fuel line and use it like a stethescope to listen real close to the manifold/head area. I chased one for a while that sounded like a loose rocker arm and finally tried the hose trick, was able to clearly hear the ticking sound when the hose was near the burnt out gasket area.
Old Sep 29, 2003 | 08:31 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
I had a similar noise on my '69 (sold).. It was caused by lose header bolts and a worn header gasket...
[Modified by GrandSportC3, 8:31 PM 9/29/2003]
Old Oct 3, 2003 | 07:46 PM
ray77vette's Avatar
ray77vette
turns out it was the chrankshaft power steering pulley. luckely for me it snapped off in my driveway. some luck huh? anyway now i have a new project
Old Oct 3, 2003 | 08:44 PM
Turbo-Jet's Avatar
Turbo-Jet
check your fan and accessory belts. if cracked, they can make a ticking sound.
Old Oct 3, 2003 | 08:45 PM
Turbo-Jet's Avatar
Turbo-Jet
nevermind...
Old Oct 15, 2003 | 08:10 PM
ray77vette's Avatar
ray77vette
Default Re: ticking noise (Turbo-Jet)
thanks for the help though
To ticking noise
