72 Vette Interior installation question
Old Oct 2, 2003 | 10:31 PM
cdc's Avatar
cdc
Default 72 Vette Interior installation question
I bought my 72 Vette with carpeting that had been replaced and the underseat plastic covers that protect the seat belt retractors were gone.
I have since found a pair of those covers and would like to install them.
I've never actually seen them on an original car- my assembly manual has
diagrams that appear to show that area with a section of the carpet cut away.
Can anyone tell me what is the correct way to install the covers- cut out the carpet, or mount over the carpet?
Thanks, CDC cdcastle@aol.com
Old Oct 2, 2003 | 11:01 PM
SharkAttack's Avatar
SharkAttack
Default Re: 72 Vette Interior installation question (cdc)
I would have to look to verify, but am fairly certain my '72 has them mounted on top of the carpet with a hole cut for the bolt to pass through.
Old Oct 3, 2003 | 08:09 AM
goofygrin's Avatar
goofygrin
Default Re: 72 Vette Interior installation question (SharkAttack)
i had aftermarket carpet and it was cut short of the seat, so the covers went right on the floorpan on my car...
Unless you are ncrsing do what you think works best...
Old Oct 3, 2003 | 08:11 AM
mrvette's Avatar
mrvette
Several things, when I tore my car apart some years ago, I remember clearly the carpeting was cut in a square hole top of the belt retractors...they will tend to drag and jam up if not....I did not use my covers again as they trap moisture and for a daily driven car, that's a bad idea.....
GENE
Old Oct 3, 2003 | 01:35 PM
cdc's Avatar
cdc
Default Re: 72 Vette Interior installation question (mrvette)
Thanks for the responses. I'm thinking I will cut out the square hole and use the covers as a template. If moisture is a problem, I'm wondering if putting some small dessicant bags under the covers wouldn't be a bad idea. Maybe even velcro them in place so thet don't interfere with the belts.?
Old Oct 3, 2003 | 04:51 PM
Edzred72's Avatar
Edzred72
Leave just enough carpet around the edges of the hole so that the belt cover holds it down. My carpet didn't interfere with the belt opperation, so I left some between the sill and the belt guide rod. Looks better that way too!
Eddie
Eddie
Old Oct 3, 2003 | 05:53 PM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
The carpet needs to have square holes cut in a such a way that the covers overlap the carpet about an inch on 3 sides. The side toward the door is normally cut out, but if you think it won't interfere leave it there. Make sure your drain holes at the base of the retractor well are clean for free drainage. I would not place anything inside, there is not enough room, and the dessicant packets will eventually become saturated and useless anyway. :cheers:
To 72 Vette Interior installation question
