Cam Clearance
Old Oct 6, 2003 | 11:36 PM
benjtay's Avatar
benjtay
Cruising
Default 327 Cam
Should I be worried about piston clearance with my '68 327?
Specifications:
* Duration at .050 in. cam lift: 218 intake/224 exhaust
* Gross valve lift: .462 in. intake/.469 in. exhaust
* Lobe separation: 110 degrees
* RPM range: 1,300 to 5,600, noticeable idle
[Modified by benjtay, 6:47 AM 10/7/2003]
Old Oct 7, 2003 | 01:45 AM
benjtay's Avatar
benjtay
Cruising
Default Re: Cam Clearance (benjtay)
What kind of HP increase can I expect from a Comp Cams XE hydraulic
218/224 with .462/.469 lift (.050") cam kit?
