76 Steering Column in a 71???
The 1969 -75 steering wheel is the same for the standard (non-adjustable) column and the T&T. It bolts onto the hub with six screws. However, you must have the T&T hub, extension, and telescoping hardware to work with the T&T column.
Go to http://www.corvettefaq.com and download the following:
Tilt & Telescoping 69-75 Steering Wheel and Horn Parts
Tilt & Telescoping 76 Steering Wheel and Horn Parts
Std Column 69-75 Strg Wheel and Horn Parts
These three pictures show the differences in the three systems.
[Modified by Jim Shea, 7:30 AM 10/10/2003]
I installed a 1977 steering wheel in my 1976 years ago. The only slight problem that you will discover is that the 1977-82 extension is a little bit short when you install it on an early column. What happens is that if you telescope the column all the way rearward, there will be a slight gap that appears between the lower edge of the extension and the top of the steering column. But who wants to drive around like a NASCAR driver!
Or you can just begin looking for the 1969-75 extension, hub, horn, and telescoping parts to work with your original steering wheel.
