ground wire
Old Oct 14, 2003 | 06:29 AM
lil ski's Avatar
lil ski
Default ground wire
I found a grounding strap connected to the frame near the passenger side front wheel. Where should the it be grounded to?
Old Oct 14, 2003 | 07:04 AM
mrvette's Avatar
mrvette
Default Re: ground wire (lil ski)
It typically goes under one of the engine mount bolts....thereby making good solid connection between the engine and frame....as the negative battery pole is connected to the frame under the battery box....you need that as the only other grounding would be through the exhaust system....
GENE
Old Oct 14, 2003 | 07:24 AM
lil ski's Avatar
lil ski
Default Re: ground wire (mrvette)
Thank you I'll put it there asap.
To ground wire
