alarm won't shut off
Old Oct 22, 2003 | 02:45 PM
weez's Avatar
weez
Cruising
Default alarm won't shut off
Today I started my car and it wasn't running right so I went to increase idle. The car acted like it was ready to stall, then all of a sudden the alarm went off. I have no idea how to get it to shut off. Does anyone have any suggestions?
Will
Old Oct 22, 2003 | 03:13 PM
GreyGhost's Avatar
GreyGhost
Default Re: alarm won't shut off (weez)
This probably has nothing to do with what you explained but, my alarm would go off sometimes while driving...just a blip now and then. I then locked the car and then unlocked it with the key in the drivers door and that stopped it from going off.
Old Oct 22, 2003 | 04:07 PM
weez's Avatar
weez
Cruising
Default Re: alarm won't shut off (GreyGhost)
I tried locking and unlocking the door, but that didn't help.
Old Oct 22, 2003 | 04:54 PM
Wrencher's Avatar
Wrencher
That's what ya' get for trying to steal your own car, man!
Seriously, it's wierd that it ran bad, then the alarm started up. Sounds like a short to me...
Hans
Old Oct 23, 2003 | 07:31 AM
GaryS's Avatar
GaryS
Year of car? Aftermarket or original alarm?
Gary
Old Oct 23, 2003 | 01:15 PM
weez's Avatar
weez
Cruising
Default Re: alarm won't shut off (GaryS)
Its a 77, and the alarm is original.
Old Oct 23, 2003 | 09:05 PM
SnoDrgn's Avatar
SnoDrgn
From: Swords Check/Saws Check/Clubs Check/Claws Check/Hatred Check/Anger Check/Murmaid Check/Murder Check
Cruise-In IV Veteran
Cruise-In VI Veteran
Don't know if it's the same as my 74 but there should be a microswitch behind the cylinder for the alarm. I can't remember exactly how it works but I think when the alarm is armed this switch makes contact with the rear of the cylinder. If the cylinder were to be tampered with (i.e. someone trying to remove it to steal the car) the switch would close and active the alarm horn. It's been a a couple of years but I remember having some problems with the switch and just unplugging it. It's on my "to do" list when it comes time to pull out my evap canister to replace the filter. :crazy:
Old Oct 26, 2003 | 08:41 PM
SnoDrgn's Avatar
SnoDrgn
Default Re: alarm won't shut off (SnoDrgn)
Here's a pic of the bracket behind the alarm cylinder (my wires are disconnected). The microswitch goes through the hole in the center and makes contact with the cylinder.
http://www.ecklers.com/product.asp?p...N0SM2EP34H0KAE
Old Oct 27, 2003 | 12:29 PM
weez's Avatar
weez
Cruising
Thanks for the pics
To alarm won't shut off
