Steering question
Old Oct 24, 2003 | 01:46 PM
Munky's Avatar
Munky
Default Steering question
I do not have tilt/tele in my c3, and was wonderin if anyone else has an issue with leg to wheel clearance? I have manual steering, so if I put another steering wheel on it will it be a royal P.I.A?
Thanks.
Old Oct 24, 2003 | 05:42 PM
mrvette's Avatar
mrvette
Default Re: Steering question (Munky)
one of the FIRST things I did was a late shark smaller diameter, thicker grup wheel.....on my '72.....then I did a TT conversion....then finally a couple/years ago....cut the front floorpan, and moved it forward...and lowered the pedals...and dropped the seat back tracks down allmost 2 inches...this makes the car driveable....
GENE
Old Oct 24, 2003 | 11:15 PM
Munky's Avatar
Munky
Default Re: Steering question (mrvette)
Thanks Gene - I plan on doing a TT conversion this winter, along with the wheel - some great ideas that you have. I am 6'0, and not that large a guy, but man.... it is difficult to work the turns with the wheel in my lap,,,
thanks again
Old Oct 24, 2003 | 11:35 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Pulling the steering wheel isn't THAT big a deal if you can do normal car stuff...
I'd say do it!
Old Oct 25, 2003 | 07:51 AM
CF6873's Avatar
CF6873
Default Re: Steering question (427V8)
I believe that 68 had the biggest wheel of them all. Very tight clearance between the wheel and seat. I put on a 2" smaller wheel unless I'm going to a special show. It is only 6 screws,I think, to change it. It makes it alot easier. Craig
To Steering question
