Got it off - with a special puller, boy was that on there tight. Another problem now though, when I try to re-install the tie-arms the stud turns when I try to tigthen the bolt back up, is that normal ????? How do I get it on there if so
I'm :confused: . Can you please explain this a little better. Are you talking about tie rod ends and sleeves?
Where both the right and left inner tie rod ends connect, they have stud that goes through the rod, and have a bold & pin keeping it installed. When I try to install the bolt, the stud turns after only a 1/4 turn.....
How do I keep stud from turning to get nut on tight ?
