compression check
Old Oct 24, 2003 | 07:00 PM
l2vette's Avatar
l2vette
Default compression check
Does anyone know the correct proceedure for performing a compression check (hot or cold engine)???
Thanks.
:cheers:
Old Oct 24, 2003 | 07:03 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: compression check (l2vette)
hook it up, set throttle to full open, cycle a few time till pressure does not increase.
Old Oct 24, 2003 | 07:46 PM
Jvette73's Avatar
Jvette73
Default Re: compression check (Twin_Turbo)
also remove all the spark plugs before testing. this kills the drag from compression so the engine will spin faster with the starter and get a better reading on the gauge
Old Oct 24, 2003 | 07:48 PM
Jvette73's Avatar
Jvette73
and dis-able the ignition so you dont risk a fire with the wires hangin there. Un hook the hot wire to the dist or coil.
Old Oct 24, 2003 | 11:22 PM
l2vette's Avatar
l2vette
FUll Throtle while cranking engine???
Old Oct 25, 2003 | 12:36 AM
blunsford's Avatar
blunsford
Yes, full throttle with the ignition disconnected. The throttle does not have to be WOT, but it does speed things up a bit.
To compression check
