my l-46 motor has 64 c.c. combustion chambers. i'm looking for the c.c. size for the intake runners. i'd like to replace my heads soon, and need this info for replacement factor...thanx for any help.. :thumbs: :seeya
Since your vette is a '70, I think you have either one of one of the follwoing:
"186" – 3927186. Another good performance head. They were found on 1969-1970 302 and 350 engines. They had 2.02/1.60" valves, 64CC combustion chambers, DO have accessory holes, intake port volume should be 161CC's, exhaust port volume should be 65CC's. These heads have double hump casting marks.
or
"041" – 3947041, also 3947041X. A good performance head. They were found on 1969-1970 302 and 350 engines. They had either 1.94/1.50" or 2.02/1.60" valves, 64CC combustion chambers, DO have accessory holes, I don't have port volume data for the regular 041, the 041X intake port should be 165CC's, the 041X exhaust port should be 65CC's. These heads have a single somewhat triangular shaped casting mark (slope on the upper left).
If you want to stay with Iron heads, the Vortec heads are really nice and cheap. You will need a "Vortec" style intake manifold. You can also try to S/R Torquer.
Where is Westmoreland, NH? I am originally from Milton, NH.
