Side Pipe Cover Install (Standard)
Old Oct 26, 2003 | 05:48 PM
OHSIXX's Avatar
OHSIXX
C2 of Year Finalist (performance mods) 2019
Default Side Pipe Cover Install (Standard)
Mine are still in the boxes, but will be puting them on tomorrow in prepration for going to "Muffler City" later in the week.
Looks like just six screws on each side or are their some other brackets, etc?
How much time to do?
BTW, I have not unpacked them yet!
Old Oct 26, 2003 | 08:30 PM
72ls5fla's Avatar
72ls5fla
Default Re: Side Pipe Cover Install (OHSIXX)
Mark,
In addition to the 6 screws per side, there is a bracket that bolts from the frame rail to the rear of the covers (near where the exhaust exits).
I know for sure with factory covers, becuase of weight and such, this bracket is a necessity !!
There is also a recessed bracket - on fatcory pipes - that mounts up front near where the sweep begins on the front of the covers, also for weight / support.
Also .. hope you bought the mounting hardware kit - it has all the insulators and correct bolts.
Won't take but a couple of hours to get the covers on.
I would mount the covers 1st, then have the pipe/muffler assembley put in.
Finally put the rear bracket in. It actually mounts under the exit pipe from the muffler.
Good luck.
Bill
Old Oct 26, 2003 | 10:15 PM
LFZ's Avatar
LFZ
Default Re: Side Pipe Cover Install (72ls5fla)
so your saying, mount and install the sidepipe covers..then install the mufflers? i would have did the install the other way around, but if thats easier or the way it should be done...then thats interesting. good information. :thumbs:
Old Oct 26, 2003 | 10:43 PM
Barry's70LT1's Avatar
Barry's70LT1
Old Oct 27, 2003 | 04:05 PM
OHSIXX's Avatar
OHSIXX
Default Re: Side Pipe Cover Install (Barry's70LT1)
Thanks for the tips! I will be doing it later tonight. :)
To Side Pipe Cover Install (Standard)
