L88 engine for $15,000???????
Old Oct 26, 2003 | 06:34 PM
Corey_68's Avatar
Corey_68
Default L88 engine for $15,000???????
What are the odds that this is one of the original 20 L88's made?? :rolleyes:
http://cgi.ebay.com/ebaymotors/ws/eB...category=33615
Old Oct 26, 2003 | 06:48 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Default Re: L88 engine for $15,000??????? (Corey 68)
Well if it's on Pee-bay, it's gotta be real! :lolg: Unless you're tracking down a certain engine #, you can build one for a lot less. Buyer beware. :yesnod:
That one makes at least 200 documented '67's. :lol:
Old Oct 26, 2003 | 07:14 PM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: L88 engine for $15,000??????? (1970 Stingray)
Engine has approximately 30 minutes run time on test stand since August 2003 build. Engine does not leak, smoke, knock or run hot. It holds 50+ psi oil pressure at idle.
Seems to be an repro L88
Old Oct 26, 2003 | 08:36 PM
PROSOUTH's Avatar
PROSOUTH
From: Manchester, Dead Center in the Middle of TN 25 miles to Jack Daniels,10 miles to Geo Dickle, and .8 mile from the Liquor Store at I-24 Exit 114
St. Jude Donor '05
Default Re: L88 engine for $15,000??????? (Guru_4_hire)
I believe this is the same engine we saw in Knoxville at EXPO the other day. If so I looked at this engine and the ZL-1 I told DEP about was in the trailer.
JIM :seeya
Old Oct 27, 2003 | 12:11 AM
PRNDL's Avatar
PRNDL
[QUOTE]What are the odds that this is one of the original 20 L88's made?? :rolleyes:
zero to one? He says no vin. So if he is claiming anything (and I can't tell what he is claiming) it would be an over the counter engine. Weren't they available back then? MJ
Old Oct 27, 2003 | 07:20 AM
groovyjay's Avatar
groovyjay
I'd rather spend my 15K for a real big block like 632CI or something in that bal park. :yesnod:
Old Oct 27, 2003 | 10:50 AM
sammyb's Avatar
sammyb
Default Re: L88 engine for $15,000??????? (groovyjay)
Unless he has documentation of the engine being owned by one of the racing teams that owned L88s, it is FAKE.
Old Oct 27, 2003 | 01:45 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
There were 20 Corvettes ordered with the L-88 in 1967. That doesn't mean GM only made 20 engines. There were others that were never installed in a Corvette but rather sold as crate engines to such places as Baldwin Motors. That could be why this engine has no VIN stamped on it. Still it's too much $$ unless you own one of the 20 cars and need an engine for a correct restoration.
[Modified by 6t9l4t6, 1:46 PM 10/28/2003]
To L88 engine for $15,000???????
