Rear Spindle max torque?
Old Oct 27, 2003 | 09:47 AM
KJL's Avatar
KJL
Default Rear Spindle max torque?
How much torque can a stock rear spindle take? I am assuming GM used the same rear spindle for both the big and small applications. Who makes a good high performance rear spindle?
Old Oct 27, 2003 | 09:50 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Default Re: Rear Spindle max torque? (KJL)
Yes all spndles are the same. No one makes a HP spindle unless you jump up to the 30 spline spindles and side yokes. Guys running that set up are usually in the 750 HP range and up. The only thing you can do to stock spindles is to cryogenically treat them. That will make them hold up longer.
Old Oct 27, 2003 | 10:14 AM
Tom454's Avatar
Tom454
Default Re: Rear Spindle max torque? (Van Steel)
http://www.tomsdifferentials.com/tomp.htm
There are others
Old Oct 27, 2003 | 12:01 PM
Van Steel's Avatar
Van Steel
Default Re: Rear Spindle max torque? (Tom454)
I make the same thing as Tom's
http://www.vansteel.com/index.cfm?fu...ups&Group=9000
To Rear Spindle max torque?
