What motor should i make
What would be the cid on a 454 block/ bore to a 4.331/stroked to 4.375 with 6.385 rods,,,,is this combo even possible????
I want a tire shredding monster that can wrap up quick!!!!!!!!! :steering: :confused:
[Modified by Titanium Rat, 12:32 AM 10/30/2003]
1. Will it fit in your block? This all depends on the exact rod that you choose, but no matter what it will be real tight in there, and require custom work to make everything fit.
2. Who makes an affordable 4.375" crank that will fit your block and 6.385" rods? Most stroker big blocks are built around a 4.25" stroke and 6.385" rods because it fits, it's readily available, and most importantly you won't need a mortgage to pay for the parts.
My vote would be for either a .030 over 489 or a .060 over 496, but they're not in your poll. Build it as big as you can, then put the parts into it that deliver the power you want. Sure, a 427 can run over 7000 rpms, but there are also 540ish engines here on the forum putting out over 700hp and running over 7000 rpms on pump gas without any extravagant parts. That's a tall order for a short stroke mill like a 396 or 427. If you're in the drivers seat, I don't think you'll be missing any rpms... :crazy:
[Modified by Flareside, 9:12 AM 10/30/2003]
Why do people :confused: confuse short stroke with faster revving motor????
build these motors up equally with a high performance rebuild.
Take a 69 Z-28 302 ci with a 4.11 rearend and put it in 4th gear at 40 mph
Take a 69 Z-28 427 ci with a 4.11 rearend and put it in 4th gear at 40 mph
Take a 69 Z-28 496 ci with a 4.11 rearend and put it in 4th gear at 40 mph
All cars stomp on the gas at the same time.
Which car gets to 120 mph first?
The one with the most TQ!!!!!!!!!! The 496 could have probably got up to 120 and be stomping on the brakes to a near dead stop by the time the wimpy 302 even gets to 120 mph.
Give us some more ideas on the money you want to spend, HP goals and hood clearance issues and you will get more specific advise.
69ratt, ive done a lot of thinking today
i guess im looking to stay into the 550-650 HP range without the NOS,,,, the sky is the limit with the money on this motor(but im not going to go all out because its not really needed///its a weekend car not a dragster)
for example----i will probably go with some good bowties and have some headwork done,, or get AFR's with some minor headwork........but i wont get a 2500-3000 dollar set of heads then have 5000 in machinework done to them if you get my point,,, dont need to, i only want 600 maybe 650 HP i can get that easy strait out of the box.
The parts i will buy will be the best i can find,,,,,which is where advice from you fellows will come in and advice from the machinest.
I will be using my current NOS system on this motor its a 150shot. I have a 454 block that a 2 bolt and i am ordering the Mildon 4 bolt maincaps and will have those machined in.
I am leaning towards an eagle 4340 4.25 crank
with eagle 4340 Hbeam 6.135 780gram rods
it will be bored 60 over!!!!!!!!!
a hyd roller cam.
and yes the 10.5:1 sounds somewhere in my lines,,,,,,,,,,what pistons would be the best?????
My biggest question,,,,,,,,WHAT CAM? :confused: :confused: i want something that rumbles a crazy rumble but still lets me use my vacume stuff,,,,,,,,no more than 6500 rpms i dont need anymore than that :crazy:
I want to keep the motor stock looking (you know!!! use stock valve covers, paint the nicely ported aluminum intake, paint the New high HP heads orange on the outside), so i was going to go with a duelplane, and i want to keep the stock hood. :blueangel:
[Modified by Titanium Rat, 7:48 PM 10/30/2003]
If it were my motor I would get the AFR 315 CNC heads set up for a roller cam. No more work needed to them. They are kick a** out of the box.
If you choose a hyd. roller I would look at something in the 252 + at .050 (hyd. cams act approx 8 * bigger than a solid) You need to post your tranny / stall, gears, combo to get a better idea. Comp has a couple of good ones. A radicle idle will not be a problem, neither will making your power brakes work.
Get the L-19 rod bolt upgrade for your rods.
A Dominator would make the most power, but you may find the Holley HP series easier to tune, more steetable, easier to find air cleaners for etc. If you go the HP route get the 1000. I run one on my 454 and love it. Ask Holley if you should go with the annular or down leg boosters, your motor is probably a toss up.
Although you do not "need" them I really like JE pistons, SRP's would be fine for a 150 shot. Tell JE you are going to run nitrous and they may move the rings down, maybe not for such a small shot.
i dont really care about the hood problem i was just trying to stay stock looking, rather than choke my baby i will just get a l88 style hood (i think they look good anyway)
Th400 tranny and a 3.08 gear 2500stall (the 308 stays!!!!!!!!so dont even say it:lol: ) i just took out the 390 gear,,,,,,,i dont like taching 4 grand on the highway :nonod:
thanks for the help RATT
