3/8 BB rod prep question.
Old Oct 30, 2003 | 08:43 AM
ImBatman's Avatar
ImBatman
Default 3/8 BB rod prep question.
I have a set of stock 3/8 rods for my 30 over 454. I plan on replacing the rod bolts with ARP's and I am going to have the entire rotating assembly ballanced. It has been recommended to me that I polish the sides of the rods and remove the casting marks. I have done this to one rod already but want to make sure I have not weakened the rod. I used a grinding wheel to take of the casting on the beam of the rod. Then I used a dremel and paddel wheel to buff it out. I only took off enogh metal to level the side of the rod. Is this OK?
