Alternator problems help plz!!!!!!!
Old Oct 31, 2003 | 01:35 AM
76BlackStingRay's Avatar
76BlackStingRay
Default Alternator problems help plz!!!!!!!
i got a powermaster 140AMP alternator http://static.summitracing.com/globa.../pwm-67294.jpg it worked before but i did some converting to my belt system now the alternator is running off a 4inch pully. and it dosent start to make any power untill it hits like 2k RPMs. Can i do anything about this? is it a broken alternator? or is it just made for high RPMS? can i get one that works of littel rpms?? :banghead:
[Modified by 76BlackStingRay, 6:36 AM 10/31/2003]
Old Oct 31, 2003 | 07:47 AM
pws69's Avatar
pws69
Default Re: Alternator problems help plz!!!!!!! (76BlackStingRay)
This is typical for high output alternators - they need higher RPM's to generate output. Not usually friendly with "underdrive" pulley systems. I would go back to the stock diameter (or smaller if you have the full "underdrive" set of pulleys installed) pulley for the Alternator.
