75 Heater control valve ??
Old Nov 1, 2003 | 05:58 PM
GTR1999's Avatar
GTR1999
Default 75 Heater control valve ??
I don't have a vacuum print on the 75 Heater(no A/C) system. My question is how does the heat control valve work- vacuum when the roller dial is in the heat setting or cool. I would thinking in the heat setting for collant to flow int o the heater core. I should have engine vacuum at the line? I have no hot air in heat or defost with the line connected,hot air with the line off but no vacuum in either hot or cool dial setting?
Thanks,
Gary
[Modified by gtr1999, 5:58 PM 11/1/2003]
Old Nov 2, 2003 | 12:27 AM
Cookwithvette's Avatar
Cookwithvette
Default Re: 75 Heater control valve ?? (gtr1999)
Coolant valve defaults to open position. Vacuum should be present on that line when **** is in cool position.
Sorry I don't have much more to offer, I never did finish fixing that system. (Got side tracked)
Good luck! :cheers:
Old Oct 2, 2013 | 09:22 PM
Plasticfreak's Avatar
Plasticfreak
Does it come out of the firewall somewhere? A white vac tube?
To 75 Heater control valve ??
