Headlight question
Old Nov 1, 2003 | 06:00 PM
kaz1961's Avatar
kaz1961
Default Headlight question
The drivers side headlight on my 75 works properly about 50% of the time. When it doesn't work right it will get stuck in the up position. Usually turning the lights on and off a couple of times makes it go down. Tonight it stayed up when I parked it but went right down when I later started the engine. Everything under the hood looks brand new and I believe the whole system was rebuilt or replaced by the previous owner. Is this a vacuum problem? I don't want to mess with it unless it is a simple fix because I can always get it to work as is for now. Any advice would be greatly appreciated. :steering:
[Modified by kaz1961, 11:00 PM 11/1/2003]
Old Nov 2, 2003 | 10:19 AM
Jack71's Avatar
Jack71
Default Re: Headlight question (kaz1961)
Is it related to how hot the engine is? The only way to really see what is going on in there is to hook up a vacuum gauge. It might be on the fringe of "permanently" breaking...
Old Nov 3, 2003 | 08:03 AM
Frank75's Avatar
Frank75
Default Re: Headlight question (Jack71)
It's also possible for the mechanism that lifts/holds the headlight in place can be almost "over center". It's a hinged affair that can be adjusted - mine worked a whole lot better when I limited its upward travel a bit. You might have to remove the grill or other bodywork to see this properly though.
To Headlight question
