Is this the TCS wire??
Old Nov 2, 2003 | 02:30 PM
72Shark's Avatar
72Shark
Default Is this the TCS wire??
I have found a wire with no home on the '72. It is a 10 or 12 AWG wire, black, with a single female connector on the end, and is on the driver's side of the engine compartment. The connector is made of a hard rubber like material, and is round. The connector inside is for a flat male connector of course. It looks like it may have been the TCS wire??? My TCS is not hooked up, but the old "sensor" is still in my Muncie. The wire goes through the firewall in the bundle of wires down low below the brake booster, but closer to the transmission tunnel. Any help appreciated!!!
Old Nov 2, 2003 | 02:51 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: Is this the TCS wire?? (72Shark)
I believe you are correct sir. I just pulled my muncie last week and now this wire is just haning in the air now.
