a/c question
Old Nov 2, 2003 | 11:10 PM
Clown Puncher's Avatar
Clown Puncher
Default a/c question
My a/c seems to kick on , but doesn't blow anything. I can hear it and it has been filled, but for some reason it is not blowing. I know nothing about a/c so any help with it would be greatly appreciated.
Old Nov 3, 2003 | 12:32 PM
Missileman's Avatar
Missileman
Default Re: a/c question (Clown Puncher)
Need more info. By not blowing, do you mean air from the vents? If so, then you might have a vacuum situation, either from the engine, or the selector valve in the console, or the air door located in the center plenum behind the gauge console.
If it's not cold and you know it's properly charged, then check the POA valve. If the oil drain line is frozen over, then you have a stuck POA and will keep freon from reaching the evaporator.
